It has passed the initial review by Google and will soon enter the closed testing phase.I have prepared a single binary that runs on Android 11 and above, but Google requires "new apps" to run on Android 13 and above, so that's what I've prepared.
I would like to share the URL of the application so that everyone can participate if possible. Closed testing must be done by at least 20 people for 14 days.
As for the current state of the app, it is a slightly updated version of the one that is available on my site as an Android 13 and 14 version.
I have left the reverse sync for GoneMAD, but I am not sure if the current process of getting access to stats.xml is sufficient. However, if you have access, the process has not been rewritten, so the reverse sync should work as it did in the past.
https://play.google.com/store/apps/details?id=kim.tkland.musicbeewifisyncYou will need to add your email address in order to participate in the closed test. To do this, you can either choose to have me add them individually from the admin page.
Once your email address is registered, you will be able to access the Google Play Store from the URL above, and you will be able to install the test version.
This is a tedious procedure that only Google can handle, but if you are still interested in participating, please send an email to
[email protected]Some points to note on the specifications
・Only music files and playlist files can be copied due to MediaStore limitations. As was reported here the other day, image files will result in an error. Please embed the cover art in the music file and transfer it.
・Due to MediaStore limitations, .m3u is added after the playlist file. However, m3u files will be transferred as is as an exception. I think there is no problem in operation about .m3u8, but I have not confirmed about wpl. Please use .m3u for playlist settings.
・I have not encountered any other unpredictable behavior that cannot be returned by wired sync, so please have your cables ready when participating in the test.
