I continue to maintain it for my own use and also publish a degud build version.
↓ Here
https://tkland.kim/?page_id=3239
If there is no problem, I will use MusicBee Wify Sync
Is it okay for me to take over the future development of the game and go through the process of publishing it on the store?
Sorry, I am Japanese. English is translated by Google
Can anybody tell me how to use this? Thanks for sharing!
This is a tool for cable-free synchronization between MusicBee on a PC and an Android device.
You must first connect and sync with a cable once.
You do not need to enter the IP address of the server, but please make sure that the PC on which MusicBee is running can communicate beyond the firewall.
Next, choose whether you want to save the music files to internal storage or an SD card.
Finally, Sync and they should be synchronized. That's all there is to the tool.
Translated with DeepL.com (free version)
