Author Topic: folder/file extension issues  (Read 706 times)
edoetschman
Hello:  So here is my delima,  I have completed making all my playlist's and sorting them out.  I wanted to make a copy
of the playlist's and Library to be contained in the File Explorer in Windows 10.  This took a little time to set up and complete but
I finished it all.  Now the problem comes from going to make and print a master listing of Folders & Files, the extension's
somehow were changed from bing all MP3 to a MBP File (Whatever That Is).  Can someone help me with this and get it
reversed back to the original MP3 listing.
Thanks, Ed
"mbp" = "MusicBee Playlist";  all playlist files have this extension, unless you tell MusicBee to use M3U.
If you are backing up the MusicBee/Library folder, which contains the PLS playlist subfolder and other components, that folder is not going to contain your actual music MP3 files;  the Library only contains the paths to those files, and relevant tag data.
