"mbp" = "MusicBee Playlist"; all playlist files have this extension, unless you tell MusicBee to use M3U.
If you are backing up the MusicBee/Library folder, which contains the PLS playlist subfolder and other components, that folder is not going to contain your actual music MP3 files; the Library only contains the paths to those files, and relevant tag data.
