feel free to create a wishlist topic with the important things you think are missing.
i'm thinking -
1. support radiotime api for a directory service and any others i discover when i investigate;
2. support last.fm 'love' for the streams;
3. maybe as a lower priority have a folder heirachy
(I've added numbers to the original quote - VX)
I guess with implementing RadioTime API users gain another long awaited feature:
4.
Recording support, and another request for thatIt would be great if MB has an option to split recorded stream to separate songs.
Implementing request no. 2 would probably be what
this user wants5.
Online streaming related improvements6. Filter radio stations
by chosen criteria .
I would like to see some more Categories in Radio Stations/Main Panel View for easy navigation and sorting (Country, Language, Network, Popularity). Favourites category is not needed because we have Rating instead.
7. Separate Radio section on the MB forum where users could ask a questions about and share the radio Playlists exported from MB just like we can share Skins.
I don't need about 15 000 radio stations from around the world that
Tapin Radio has, but I do need a list of stations from my country, neighbourhood or of a specific genre (lets say rock, 80s, News etc) , which I could use as a "Playlist.xml and share. This request could also be partially implemented with RadioTime API integration I suppose.
8.
Import selected radio stations presets.xml from third party apps9. Search
RadioSure online database and add the selected stations.
10. Integrate
Jamendo Radios, which is supported with many music players (mostly for Linux, but there are players for Windows that support it too).
http://www.jamendo.com/en/ - is not only a Radio Stations service, this is the site where you can listen to and download more than 300 000 tracks for free, it allows unlimited and legal sharing, so it's worth to support it.
11. Save the lyrics for the song that you are currently listen to as a TXT file with Artist-Title.txt filename pattern with one click only
(this would require to determine the default location for the files after first run though).
Currently this is also possible but the requested feature would require much less clicking than: Copy lyrics to the clipboard; Create a txt file; Paste the lyrics; Save it; Copy Artist and Title to Clipboard; Rename the file; Paste form clipboard; Save the file.
FEEL FREE TO UPDATE the list in case I've missed something useful.
