Author Topic: From playing now track list to track list in main panel?  (Read 1347 times)
Bizy
Hello,
This is rather basic, and might be so obvious (for some of you), yet I can't figure it out.
I browse my collection, add/remove songs to the now playing list (queue next, queue last, remove...).
Then I would like to see the tracks of my now playing list in my main panel, yet can't find a way to do that.
What I do see as a possibility is to select all files of the now playing list and add them to a new playlist.  And then open that playlist.
Yet my now playing tracks list is constantly changing...
Is there another way?
Screenshots for more clarity - hopefully :-D - on what I'm trying to say:
https://imgur.com/a/bIhBeyd
b.
Full installer Version 3_4_7805
Portable Editon 3_4_7805 P
OS: Windows 10 Home Edition
Bizy
Right.  Yes, that's something.
But no A-Z bar and no columnbrowser (not available as elements, as far as I can see).
And when I right click a song for 'edit', nothing happens (?).
Am I overlooking something?
This will be my last reply.
Just type something on the list and it will show search bar that works for the sorting column.
Shift+enter shows up tag editor in floating window for me. I don't know why it's not working for you.
And note that now playing tab has very limited options for the layout and support for other elements.
If you want to just follow the playing track, see this thread: https://getmusicbee.com/forum/index.php?topic=22491.0
Bizy
Three useful tips.
And a partial solution for what I was looking for.
Thanks for that.
Goodnight!
b.
