I've been away for a few months, but I really like most of the new changes in MB 3.0
My time away from MusicBee was a good thing, because now I can see some design aspects with a different point of view.
A few thoughts:
- Functionally-wise I believe that MB 3.0 is great. Some obscure options were lost but some nice new ones were added. It feels much more fluid to use than 2.5. I like the new panel headers (are you using a specific name for them?) and the added functionality, it's easier to change views, panel contents and use MB in general.
- The layout editor is still a bit confusing and maybe overwhelming for new users. The basics are there, but I think it needs more visual help (like the aid provided by the layout icons, I only look at them to know where to drop the panels!). Maybe when you drag a panel the allowed drop sections should change color, becoming more visible. Also the list of panels should include a collapsable description for each one. Finally the "hide/show panels" section on the bottom right should always be visible, it took me >5 minutes to find where it was!
- I still feel like some parts of the interface are a bit too much compressed. In my concepts, now that I have seen them again after a few months, the spacing is a bit high as many of you pointed out. But maybe something in between should work better (It doesn't help that right now the panel spacing settings in the skins doesn't seem to work).
To be more exact,
left panel &
playing tracks panel should have a bit more spacing between list items (but not as much as in the
now playing view!), specially the
left panel. Maybe 2-4 px more per line in the left panel and 1-2px more in the playing tracks panel. The panel headers feel a bit compressed too, maybe a height setting for them would be the ideal solution.
- On the skinning part, the new options are great, and all the basics are there. The new layout helped a lot cleaning part of the mess in the skin files. In the future I'd like to see some way to change/override panel header colors based on what panel (Left, Middle Left, Middle, Middle Right, Right) they are located. And a different setting for the main tabbar/toolbar colors when the playerbar is on top. Also a way to fine tune paddings inside panels. For 4.0 (long-term) I'd like to see a dynamic bitmap player bar that allows the 3-4 player configurations and maybe an option to set text sizes/opacities inside the skin (with an override on the settings panel, of course).
TL;DR MB 3.0 is much more enjoyable to use. I feel like most (interface) elements are ready for an eventual release; whatever fine tuning they need could come in a later version.
