Author Topic: youtube video playback  (Read 20241 times)
Adroit
Just introduced myself to this player and starting to explore it after spending many hours cleaning up my music collection.  I can't play the youtube videos - looks for plugin.  I have adobe flash installed... Is it because I'm running win7 64bit?  Or just because I'm using a dell? :P I saw only 1 post related to mine and the semi-solutions don't help me as the .dll they reference doesn't exist on my computer.
Side Note: Awesome player!! I'll be following its progress while using it!
Adroit
OK, so I downloaded the npswf32.dll internet and placed into the C:\Program Files (x86)\MusicBee\XulRunner\plugins  folder (I skimmed over the xulrunner pathway initially so make sure you go here and not straight to plugins) and video now works on the youtube tab.
Huzzah!!
silasje1
Download the 64 bits version here. It is the Flash 11 version:
http://www.mediafire.com/?63giee6uum05au1
32 bits here:
http://www.mediafire.com/?c5yc4s6e8x3c4eb
(also flash 11)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
Adroit
thanks for the links...the control parts of the video were not displaying correctly, hopefully this will fix that.
Edit: Yes it did :)
Last Edit: June 06, 2012, 03:52:27 PM by Adroit
