Author Topic: Best AIFF/WAV to FLAC converter?  (Read 20395 times)
silasje1
Hey folks,
Im on Windows 7 64 bits and would like to convert all my WAv/AIFF files to FLAC's.
Why?
I need tag writing etc. so therefore :)
Thanks in advance :)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
lnminente
I like Easy CD-DA extractor, it's not free. Haven't still used the one in MB.
silasje1
I need a freeware version ;)
it is exteremly hard to find :( STEVEN?
Last Edit: April 01, 2012, 06:50:49 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
CDex
http://cdexos.sourceforge.net/
Audacity
http://audacity.sourceforge.net/
CDex can extract the data directly (digital) from an Audio CD
so not use full.
Audacity was very hard to mange but seems to be able to convert files, but only 1 per time :( is there a mulitple file converter?
Dutch Translation
WMP 12 Skin
fre:ac (Free Audio Converter) should be able to do everything you need.
http://www.freac.org/
silasje1
Almost ;) no AIFF though :( but 10 wav files can be done now :D
Dutch Translation
WMP 12 Skin
silasje1
Try these, they should get the job done
http://www.erightsoft.com/SUPER.html
http://www.mediacoderhq.com/
i cant seem to find a AIFF support on these? I mostly need a AIFF to FLAC converter now. I already have wav to flacs now. Seems like there is no converter for AIFF->FLAC?
Dutch Translation
WMP 12 Skin
jistme
dBpoweramp can do that and has 21 day free trial.
silasje1
Ok... thanks :) i will try it and give feedback soon
Dutch Translation
WMP 12 Skin
GoodWill41
Hi guys!
I'm new to MusicBee but what I've found out so far is great!! Thank you, Steven, for that awesome piece of software.
Well, Silas, the only freeware/Free Software (Open Source) I know that are able to convert from AIFF to FLAC (because it is told in the descriptions of these programms) are
1.) winLAME and
2.) Foobar2000
But I haven't tried it. So it's up to you.
Good luck!
silasje1
Hi guys!
1.) winLAME and
2.) Foobar2000
Good luck!
Winlame cant comvert to FLAc from AIFF.
foobar2000 yet to try
Dutch Translation
WMP 12 Skin
silasje1
Did this:
covert from aiff to wav. from wav to flac. Thanks anyways
Dutch Translation
WMP 12 Skin
Igoodluck
FLAC can store files with less space, keep metadata tags, keep album cover art, and has support for fast seeking. Converting WAV to FLAC will keep metadata tags. If you prefer, you can follow the guide to convert WAV to FLAC:http://www.bigasoft.com/articles/how-to-convert-wav-to-flac-on-mac-and-windows.html
