Author Topic: question about skinning  (Read 980 times)
monkey
i searched on the forum
but i didn't found the id elements, i made some test with those i found but without success
i would like to modify colors of the column browser in vertical position (chiefly the headers) as shown below
karbock
If you install Sample Skin by hiccup, you will be able to locate each ID.
  • Install and select "Sample Skin".
  • Use any colour picker to get the r,g,b value of the desired colour.
  • Search "Sample Skin.xml" for the r,g,b code.
    Each colour is used only once in the .XML.
If you don't have any colour picker, I recommend Instant EyeDropper (free).
EDIT: Instant EyeDropper (no space).
Last Edit: May 14, 2024, 02:33:49 PM by karbock
