Author Topic: Flickering display since the last updates  (Read 1548 times)
could you send a link to your settings file (help/support/view settings)
and if you use a custom layout or view, a zip of the AppData\Saved Settings folder
mrbenn
PM with link sent.
I did try both with and without using my usual custom view and it didn't make a difference as far as I could tell.
i cant reproduce any issues but will have another look later in the week
you could try removing mb_Spectrogram-Display.dll or at least renaming it to .dll2 so it doesnt load at all
voodoopunk
Just to chime in and state that I get the same graphical glitch as mrbenn.
I'm not sure it's plug-in related as it occurred after an update and I've no new plug-ins.
It's not a bit deal really, the screen just takes a while to catch up when switching to different views. It's worse on an older machine running Win 8.1.
voodoopunk
i still cant reproduce any issues, however i have taken a guess
https://getmusicbee.com/patches/MusicBee36_Patched.zip
@mrbenn, MusicBee should start up much faster for you
mrbenn
It seems your guess is correct, as I cannot get the issue to occur at all now.
And yes, it starts significantly faster. I think from 2 or 3 minutes to a few seconds. Thank you!
Coogan
Are any of these fixes backwards compatible for 3.5?
My MusicBee Version:
3.5.8878
the flickering didnt happen with v3.5
the load time improvement has also been made to v3.5 but would not be a common improvement
Coogan
Thank you for the response Steven.  I'm still on 3.5 and don't have any issues.
3.5.8878
djmst
Hello everyone, me again,
a short information on my part:
with version 3.6.8906 P (update from 2024-05-20) the problem with the flickering no longer exists.
Thank you very much!
Best regards
