Author Topic: Bitmap based skins  (Read 132516 times)
Tom
Oh sorry, I have to correct myself. I saved the wrong file.
It IS the dpi setting which causes the problem. So your guess is absolutely correct, Steven.
I never would have expected that the dpi setting in the file can cause such a behavior. Is it possible to ignore this value on the editor?
i updated the SkinCreator.exe file so:
- it should adjust the resolution automatically
- added a parameter in the xml file for the left 4 play buttons
  <images drawPlayButton="false"
  when set to false you need to provide your own arrows on each button, and for the main Play button you need to provide a second image for the pause button
  <images category="Play" drawPlayButton="false"
    default="Images\PlayButton.png"
    highlight="Images\PlayButtonHighlight.png"
  <images category="Pause" drawPlayButton="false"
    default="Images\PauseButton.png"
    highlight="Images\PauseButtonHighlight.png"
http://www.mediafire.com/?s2rmb7v69807w11
anyone interested to develop a skin with this needs to contact me as using the above by itself wont work
silasje1
Which image editor did you used for the buttons?
adobe photoshop :) you like it?
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
Tom
Now I have completed two different versions of the player.
I know, some people like it darker and others lighter.  ;)
Hope you like them. Any suggestions and or comments are welcome.
(When hovering over the left buttons, they become orange)
silasje1
cartman005
I prefer the rounded edges of the black one. Both look great though.
Last Edit: July 01, 2011, 03:37:31 PM by cartman005
antiPOP
Steven, I can't ran Skincreator, I'm getting message "SkinCreator stopped working". Windows 7 SP1 HP x86.
Tom
yes, me to. Maybe it could have been a bit more rounded. I will give this a try.
edit:
Here it is.
Last Edit: July 05, 2011, 06:46:12 AM by Tom
Blinghound
It looks like the skincreator is down, and I did not download the updated version with the DPI fixes. Would it be possible to upload again?
Thanks
integrated into musicbee now and a new version of skincreator. Contact me by PM if you want to try it out
cartman005
Has anyone created a bitmap skin yet? I would love to try one out. The bitmap skins allows the skin creators to put their own picture for any of the buttons correct? Are layout changes allowed as well?
Tom is but he is busy with work for a couple of weeks and i know blinghound isnt too far off from one. A few others have been looking at it but not sure if they are going to release anything
Blinghound
I will have two out tomorrow hopefully, as well as a couple more this week :)
Here's a preview of the Honeycomb replacement. I still have a couple of things to work out, although I'm not sure if they are bugs. When Last.fm is signed in, the 'LastFmOn' picture does not appear in place of the 'LastFmOff'.
