Author Topic: Need help!  (Read 10279 times)
silasje1
Hey people.
I have an pieace of code now which creates an Window. The problem is:
I cant put source in it? here is the code:
using System;
using System.Runtime.InteropServices;
using System.Drawing;
using System.Windows.Forms;
using System.Collections.Generic;
using System.Text;
using System.Net;
using System.Web;
using System.IO;
namespace MusicBeePlugin
    public partial class Plugin
        private MusicBeeApiInterface mbApiInterface;
        private PluginInfo about = new PluginInfo();
        public PluginInfo Initialise(IntPtr apiInterfacePtr)
            mbApiInterface = (MusicBeeApiInterface)Marshal.PtrToStructure(apiInterfacePtr, typeof(MusicBeeApiInterface));
            about.PluginInfoVersion = PluginInfoVersion;
            about.Name = "Plugin Name";
            about.Description = "A brief description of what this plugin does";
            about.Author = "Author";
            about.TargetApplication = "Yahoo Messenger";   // current only applies to artwork, lyrics or instant messenger name that appears in the provider drop down selector or target Instant Messenger
            about.Type = PluginType.InstantMessenger;
            about.VersionMajor = 1;  // your plugin version
            about.VersionMinor = 0;
            about.Revision = 1;
            about.MinInterfaceVersion = MinInterfaceVersion;
            about.MinApiRevision = MinApiRevision;
            about.ReceiveNotifications = ReceiveNotificationFlags.PlayerEvents;
            about.ConfigurationPanelHeight = 0;   // not implemented yet: height in pixels that musicbee should reserve in a panel for config settings. When set, a handle to an empty panel will be passed to the Configure function
            PluginStartup();
            return about;
   static void PluginStartup()
         Application.Run(new MyWindow());
   class MyWindow : Form
      public MyWindow() : base()
         this.Text = "Twitter App";
         this.Size = new Size(400, 400);
         this.StartPosition = FormStartPosition.CenterScreen;
         // Label
         Label lblGreeting = new Label();
         lblGreeting.Text = "Just to tweet my songs!";
         lblGreeting.Location = new Point(50, 50);
public static void PostTweet(string username, string password, string tweet)
   try {
      // encode the username/password
      string user = Convert.ToBase64String(System.Text.Encoding.UTF8.GetBytes(username + ":" + password));
      // determine what we want to upload as a status
      byte[] bytes = System.Text.Encoding.ASCII.GetBytes("status=" + tweet);
      // connect with the update page
      HttpWebRequest request = (HttpWebRequest)WebRequest.Create("http://twitter.com/statuses/update.xml");
      // set the method to POST
      request.Method="POST";
      request.ServicePoint.Expect100Continue = false; // thanks to argodev for this recent change!
      // set the authorisation levels
      request.Headers.Add("Authorization", "Basic " + user);
      request.ContentType="application/x-www-form-urlencoded";
      // set the length of the content
      request.ContentLength = bytes.Length;
      // set up the stream
      Stream reqStream = request.GetRequestStream();
      // write to the stream
      reqStream.Write(bytes, 0, bytes.Length);
      // close the stream
      reqStream.Close();
   } catch (Exception ex) {/* DO NOTHING */}
        public bool Configure(IntPtr panelHandle)
            // save any persistent settings in a sub-folder of this path
            string dataPath = mbApiInterface.Setting_GetPersistentStoragePath();
            // panelHandle will only be set if you set about.ConfigurationPanelHeight to a non-zero value
            // keep in mind the panel width is scaled according to the font the user has selected
            if (panelHandle != IntPtr.Zero)
                Panel configPanel = (Panel)Panel.FromHandle(panelHandle);
                Label prompt = new Label();
                prompt.AutoSize = true;
                prompt.Location = new Point(0, 0);
                prompt.Text = "prompt:";
                TextBox textBox = new TextBox();
                textBox.Bounds = new Rectangle(60, 0, 100, textBox.Height);
                textBox.TextChanged += textBox_TextChanged;
                configPanel.Controls.AddRange(new Control[] { prompt, textBox });
            return false;
        private void textBox_TextChanged(object sender, EventArgs e)
            // save the value
        // MusicBee is closing the plugin (plugin is being disabled by user or MusicBee is shutting down)
        public void Close(PluginCloseReason reason)
        // uninstall this plugin - clean up any persisted files
        public void Uninstall()
        // receive event notifications from MusicBee
        // only required if about.ReceiveNotificationFlags = PlayerEvents
        public void ReceiveNotification(string sourceFileUrl, NotificationType type)
            // perform some action depending on the notification type
            switch (type)
                case NotificationType.PluginStartup:
                    // perform startup initialisation
                    switch (mbApiInterface.Player_GetPlayState())
                        case PlayState.Playing:
                        case PlayState.Paused:
                            break;
                    break;
                case NotificationType.TrackChanged:
                    string artist = mbApiInterface.NowPlaying_GetFileTag(MetaDataType.Artist);
                    break;
        // return an array of lyric or artwork provider names this plugin supports
        // the providers will be iterated through one by one and passed to the RetrieveLyrics/ RetrieveArtwork function in order set by the user in the MusicBee Tags(2) preferences screen until a match is found
        public string[] GetProviders()
            return null;
        // return lyrics for the requested artist/title from the requested provider
        // only required if PluginType = LyricsRetrieval
        // return null if no lyrics are found
        public string RetrieveLyrics(string sourceFileUrl, string artist, string trackTitle, string album, bool synchronisedPreferred, string provider)
            return null;
        // return Base64 string representation of the artwork binary data from the requested provider
        // only required if PluginType = ArtworkRetrieval
        // return null if no artwork is found
        public string RetrieveArtwork(string sourceFileUrl, string albumArtist, string album, string provider)
            //Return Convert.ToBase64String(artworkBinaryData)
            return null;
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
if anyone else can help please do, otherwise i am busy for now but will try to have a look on sunday
i think you cant do basic authentication anymore and need to use OAuth Authentication
check out this:
http://apiwiki.twitter.com/w/page/22554657/OAuth-Examples
my suggestion is to build a standalone windows form application first and when you have the API calls sorted, i can give you advice on how to integrate with the MB API
silasje1
im a noob to this! it took me a while even to show up this window!
Dutch Translation
WMP 12 Skin
