Author Topic: Translator Q&A  (Read 529472 times)
not for version 2.0 - i will look at it for the next version
butty
Hi, What is "Lyrics?" in Main.field.63?
Does it mean just "Lyrics"?
'Lyrics' is a song text and 'Lyrics?' tag has value 'Yes' or 'No' (i.e. this tag marks if lyrics exists in the track).
butty
silasje1
the new 2.1 translator file includes alot of old entries?
#PLE.tab.DDC51FBA#   Settings (new file)
#PLE.tab.DDC51FBA#   Speelt Nu tabblad (old file) should mean something like Now Playing Tab
i have noticed more of these mistakes..
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
i changed the Track and Artist panel settings and some of the values might be re-used or changed - i didnt do a good job of commenting the changes. But the end result should be correct i hope
jistme
In the English file I stumble upon this entry:
! Tags(1) preferences - changed from "do not show folder.jpg artwork"
#Sys.ctl.6AEFF047#   do not scan folder.jpg artwork
However this doesn't show in Tags (1) preferences.
Should it, or is it obsolete?
jistme
Not specifically a translation issue, but there is a spelling error in a MB folder.
(Plugins/TheaterMode.EmbededPlugins/TheaterMode.Embeded)
'Embeded' should be 'Embedded'.
(is also mentioned in the latest translator file)
you are right but its too late now
Roadrunner
The new custom tags 10-16 are a little bit longer than 1-9, so in the German version they reach into the "display name" field. Even 1-9 are a little bit to long, but 10-16 cover up the first letter of the name:
Lakrits
Hi Steven,
What do you mean by "left-and-right filtering" (Sys.ctl.D2C7F133)?
I can't quite figure out what it does …
Lakrits
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
   Du hittar svenska språkfiler i den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
  In hoc filum documenta linguae Latinae nancisceris.
oops, something i started but havent and might not implement - please disregard it
Lakrits
Consider it disregarded!
(BTW, my new coffee brewer has its filtering device on the left side, that's just not right….)
Lakrits
Hi Steven,
In version 2.1.4770, there are three unlocalised strings in the Now Playing panel's layout configuration window. They are three tab titles – Track Details, Lyrics and Artwork – under the section "Show track details". Please see the image below (click it to make it larger, if needed. This is apparently what my image host considers to be a "thumbnail" …), the strings in question are marked with a red border.
Lakrits
Last Edit: January 24, 2013, 04:52:15 AM by Lakrits
try
#NPL.tab.655DE83F#   Track Details
#NPL.tab.705229AC#   Lyrics
#NPL.tab.A90A4114#   Artwork
i will add to the next file
