Author Topic: Translator Q&A  (Read 530294 times)
silasje1
This seems untranslated:
Bump ^ is this my bad or is this a error (the english part is untranslated)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
if you are refering to the auto-playlist names then they will not be translated. if its the other things it will be something missing in your file
silasje1
Ok.. it was what you think :) The untranslatble text
Dutch Translation
WMP 12 Skin
Steven, some strings are now not localized in latest MB release
Roadrunner
Hi Steven
In new.txt for MB 2.0.4572 there are 2 ignored fields:
-#Main.menu.Disabed#   -->   should be called #Main.menu.Disabled#
-#Main.msg.playtrack#
An older question was:
I tried to translate Greb's Theater Mode Plugin, but stock on two menu items called "Main Bar [#]" and "List [#]". I suppose because of the #-sign it isn't possible to translate them or I don't know how: "#TMP.txt.Main Bar [#]#" at least isn't correct... ???
Should I ask Greb to replace the "#" by letters, i.e. "No"?
Thx for continuing the great work!
-#Main.menu.Disabed#   has been corrected in the translation file for the next update but anyone reading this can of course fix it now
-#Main.msg.playtrack# has been fixed in MusicBee for the next update
for the # thing, yes its problematic because of the way the parsing works. Could you approach greb and if he is not available to change it then i can look to see what could be done but i would rather not need to make a change to the parsing if i can avoid it
jistme
And while on the subject of misspells...
Xyzzy
It looks like in File Converter Cvt.ctl.12CD9693 is used instead of Cvt.ctl.F56B26B4 ?
Also, in Preferences/Layout #Main.menu.THorizont# & #Main.menu.TVertical are used  instead of #Sys.ctl.586D8565# & #Sys.ctl.4D64A009#
Last Edit: July 16, 2012, 01:52:15 PM by Xyzzy
i think its correct:
Cvt.ctl.F56B26B4 should be used for the option "under play and skip count"
Cvt.ctl.12CD9693 is unchanged and for the" artwork" options
thats correct - they used to be radio buttons but are now in a drop down box
Roadrunner
Hi Steven
During translation process I try to find the places where the text is used, to see, if I found the right words in the context and if there's enough space.
Maybe they are just in front of my eyes, but this time I couldn't find (MB 2.0.4612, Win XP):
#Main.msg.CStft0bdd# CONFIRMATION: Set tags for the {0} being drag/dropped to {1} '{2}'?
#Main.menu.TAllFile# Tick all Files
#Main.menu.UTAllFile# Untick all Files
Could you give me any advise?
these were taken out of MusicBee at the last moment so are not used any more (you acheive the same by clicking the tick column header)
drag a file to a value in one of the track browser columns and it would prompt you to confirm the tag value should be changed
Russian translation is updated according to MB 2.0.4612
Lakrits
Hi there Mr. localisation-coordinator-guy,
I have made a series of screenshots of all the (relevant) unlocalised strings that I could find in MusicBee v.2.0.4612. Please find those, and a TXT file with short explanations where needed, in the ZIP file available via the MediaFire link below.
All images are in PNG, and all strings/lists that I found to be unlocalised have been marked with red borders.
http://www.mediafire.com/?z4bglxkzo1g6q1c     [downloads "MusicBee (v.2.0.4612) unlocalised strings.zip"]
Regards,
Lakrits
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
   Du hittar svenska språkfiler i den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
  In hoc filum documenta linguae Latinae nancisceris.
