this should address many of the french layout issues in the system preferences, tag editor, file organiser, password prompt
http://www.mediafire.com/?op85zltazakzznmthings i could still see:
- can the Now Playing preferences be looked at where one checkbox in the popup notifications section needs to be abbreviated
- in the File Converters tab, the first 2 fields, could they be abbrieviated if possible
- in the Devices tab, the 2nd tab, could that be shortened? eg. remove 'options de' ?
- in the CD Ripper, is there anything that can be shortened with the 'one file per album...' - maybe remove the word embedded?
i tested using this as the first setting in the language file:
#Main.msg.abefopv# aaaaaaaa bcccdddd eeeeeeeeeeee ffgghhhhhhiiiiiiijkllll:mmnnnnnnn oooooooo ppqrrrrrrsssssstttttttttuuu vwwxyyzxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
also i added an id for the "Close Tab" #Main.menu.CloTab#
i will distribute an updated new.txt file later just in case there are more missing items found
