Author Topic: Translator Q&A  (Read 530167 times)
B77. B78. both done
added support for translating key descriptions - 2 examples in the updated new.txt file
.exe includes more layout adjustments for the german translation
additional items added to the english base file in date-added order
http://www.mediafire.com/?ymgnkibc8da2bm3
updated .exe
http://www.mediafire.com/?42a2dccq0j8493c
silasje1
thanks, fixed now.
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
carloscs
In the latest new.txt file:
! value separator used in the file summary on the bottom right of the main panel eg. 10 files, 11MB, 2:40 - preserve the trailing space
#Main.msg., #      ,
1. Very bad: the editor I use strips trailing spaces on save and I'll have to use another external editor to add the missing space...
2. and more important: it's very difficult veryfying if the space is missing, and easy for it to go astray.
Would it be possible for MusicBee to add the space in after reading this setting from the file?
andrea.ippo
With all the due respect, but such an editor doesn't deserve to be used in my opinion (or at least it should allow to disable such an option).
I highly recommend Notepad++
it now adds a space if none is present
andrea.ippo
Steve, I can't get to work these translations
#Main.key.Insert#   Insert
#Main.key.Enter#   Invio
#Main.key.Right#   Freccia destra
#Main.key.Left#   Freccia sinistra
#Main.key.Space#   Spazio
#Main.key.NumMinus#   Numpad -
#Main.key.NumPlus#   Numpad +
#Main.key.Del#   Canc
I'm using ver. .4153
Do the IDs I've added actually exist?
I was using Word for my translation first, but after you mentioned that you use Notepad++, I also begin to use it. As it turned out Notepad++ is very convenient for such tasks.
I think you must download .4157:
Last Edit: May 21, 2011, 10:40:34 AM by boroda74
andrea.ippo
It also comes with a Compare plugin that helps a lot for translation: just open both files (original + localized) then ALT+D ;)
#Main.key.Del#   Canc
you need the updated .exe linked to above
silasje1
with the duch tranlation the about musicbee screen is too small (width needs just a little more) 5 letters arent visible.
Dutch Translation
WMP 12 Skin
andrea.ippo
#Main.key.Del#   Canc
Thanks to both.
Steven, could you link the latest exe for translators in a more visible place for the future? I sometimes find it difficult to find it
Thank you
EDIT:
some problems with these, which don't seem to be recognized:
#Main.key.Del#   Canc
#Main.key.NumMinus#   Numpad-
#Main.key.NumPlus#   Numpad+
Last Edit: May 21, 2011, 10:58:10 AM by andrea.ippo
try
#Main.key.Delete#   Canc
for the other two they need special handling which i will add - the set of keys with special handling
NumPlus
NumMinus
NumDivide
NumMult
WinKey
Ctrl
Alt
Shift
Last Edit: May 21, 2011, 12:55:07 PM by Steven
Steven, what strings parameter {0} is constructed from in #Main.msg.0up#? String #Main.msg.0up# looks fine in english, but in russian it looks like '# files # files updated' :( If I change string #Main.msg.0up# form '{0} updated' to 'updated {0}' then statusbar text is '# files updated # files', i.e. something is added to the beginning of string #Main.msg.0up# and something is substituted instead of '{0}'.
silasje1
problem with that exe. The artist info doesnt get updated. When i play a next song the info of the song before still stands there.
in the version before this it worked (now using that version)
Dutch Translation
WMP 12 Skin
