Author Topic: Translator Q&A  (Read 529718 times)
butty
silasje1
#NPL.ctl.844FEA6F# is not working???? i see transparent but i putted doorzichtig here :S
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
OrB
Hello Steven
would you please check:  #Main.msg.AudioFile#   audio file
There is a translated 'audio file' in the edit-window but also a not translated 'audio file' in the filter-rules, therefore rules based on type dont work properly
or other way round: if #Main.msg.AudioFile# remains untranslated the rules on type are working
Roadrunner
Due tu the very dynamic process of the great Theater Mode Plugin with the almost daily new (also great!) XML-files from different users, I suppose the translation of this part should also be more dynamic.
At the moment, the word "from" is only found, if it is followed by a blank and a quote char, "Lyrics" isn't found at all and there's a new word "in".
A dynamic process could for example
1) remove non-letters/numbers at the beginning and ending of the text, look for translation of the remaining part, put the result together
2) search not found text in the Main.field-list (same trimming rules)
Apart from this two I don't expect too many new words, which have to be translated as currently "from" or in future "in". Expect in case of new functionality of course...
What do you (or other translators) think about this? Or do you have already your own ideas about this matter?
Last Edit: April 04, 2012, 10:34:06 AM by Roadrunner
that has been corrected for the next update
i tried just now using one of your fairly recent files and it works fine
silasje1
Still doesn't work.. some other things are untranslated too.
edit:
seems like it was untranslated>??? be back later
http://code.google.com/p/nl-for-musicbee/downloads/list
new version with fixes:
http://nl-for-musicbee.googlecode.com/files/dutch_final%202.2.lng
Last Edit: April 08, 2012, 12:42:27 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
you probably have a .xmlc file of the same name - delete that file
silasje1
it is fixed man... was something wrong in the file. see the new update ;)
Dutch Translation
WMP 12 Skin
it was changed to:
Sys.ctl.B757EA73
see the section:
! 8-April-2012
! corrections to previous new.txt
silasje1
Serious [Q]:
when i host my language file on google code and i need to choose a lisence, which one do i need to choose? This because of legacy issues? Thanks in advance
also:
Last Edit: April 08, 2012, 08:22:45 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
Wolo
it was changed to:
Sys.ctl.B757EA73
see the section:
! 8-April-2012
Oops totally missed that.
Last update hopefully
http://www.mediafire.com/?93s1ek54xsxd410
