Author Topic: Translator Q&A  (Read 529928 times)
silasje1
the text is going over the button.
 Maybe move the buttons 40px lower?
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
i cant find any of that text in your file and dont know which screen you are refering to. Can you let me know the english name
silasje1
Maybe it is an old problem.. need to use the latest dutch file or change the name.
Dutch Translation
WMP 12 Skin
Roadrunner
Hi Steven
I'm going to continue the work on the German file and have already my first questions/remarks ::)
As far as I can see, there is a text in 1.4 with no possibilty to translate:
- "Disc burning is not supported for XP"
And I suppose, for 2.0, you'll wait until the development is further, don't you?
- Nevertheless I'd like to point out a problem with the upcoming translation:
You changed the meaning of #PLE.ctl.20E7A3C0# from "Sorting and Grouping" to "sorting".
This is
1) easy to overlook for translators (because the text is already translated) and
2) wrong if one updates to 2.0 and has a not up-to-date translation file
3) also, if one downloads a 2.0 translation for a 1.4 MB...
My suggestion in such a situation would be, to create a new control with a new name and remove the old one.
Thx for your great work!
Roadrunner
point taken about changing old translated items
i will do a v2 language file tomorrow and post on the weekly updates topic
silasje1
#Sys.ctl.8091623A#   user external player:
typo? must not be use instead of user?
Dutch Translation
WMP 12 Skin
silasje1
Roadrunner
Hi Steven
Thx for the update, I like the new Theater Mode! And thx for the translation file. During translating I found some issues and have some questions concerning the new entries (as far as possible I doublechecked with the new dutch file, and there are the same problems). I hope, it's ok for you, when I post it here:
Not translatable (not found in the new file):
- Tools -> Burn Disc -> "Disc burning is not supported for XP"
- Edit -> Preferences -> Player -> "use Windows default"
Translated in the file, but the program shows still English text:
- #Sys.ctl.EC053D0C# use "flat" layout
- #AP.ctl.E34B56B1#  Remove Files
- #AP.ctl.534BF636#  Add Files
- #TMP.msg.from#  from
I don't find where the following tooltips should be showed (I could imagine, but suppose, they aren't visible at all, at least on WinXP):
- #Sys.ctl.F4B37B90# volume mute (1)
- #Main.help.MuteVol#   Mute volume
- #Main.help.EnaVol# Enable volume
And probably German specific:
- Edit -> Preferences -> Plugins -> The plugin names should begin with uppercase letter
Just in case you'd like to check my file, I've uploaded it to: http://www.uploadstube.de/download.php?file=898846
Thx for reading
Roadrunner
Last Edit: March 27, 2012, 12:49:48 AM by Roadrunner
you can change the following with no further action by me:
#Sys.ctl.EC053D0C# should be:
#Sys.ctl.B757EA73#   use "flat" layout
should be:
#AP.btn.E34B56B1#   Remove Files
#AP.btn.534BF636#   Add Files
#Sys.ctl.FC56D058#   use Windows default
the others i will address in the next update
you wont be able to see this on XP - you would need windows 7
edit:
I have uploaded the updated language file with the corrections as described above:
http://musicbee.niblseed.com/Weekly/Localisation/new.txt
Last Edit: March 27, 2012, 10:32:23 AM by Steven
Roadrunner
Thank you for the fast answers and the corrections: Works like a charm (File updated in the German thread)!
Last Edit: March 27, 2012, 11:09:15 AM by Roadrunner
butty
Hi, I have some questions on translating 2.0 into Japanese.
1. What is "Unblock"ing? (Main.msg.UntlVSp, etc.)
In my Japanese Win7 has no "Unblock" in Properties of Explorer.
2. In Sys.ctl.F4B37B90, what "(1)" means? Not "{1}"?
3. On LFM.msg.view, does the word "view" mean a new concept/feature, or it is just a View menu?
And, please tell me how to display this string.
Thanks in advance.
butty
for 1, you will only see it on .exe and .dll files directly downloaded from the internet (i dont think it happens for unzipped files)
Blocking is a security measure by windows and then a file is blocked, some software wont load the file. It requires a manual step by the user to right click on the file/ and click the Unblock button (but you only see that button if the file is blocked)
2. If you go to Preferences/ Player/ Taskbar Player you will see what it means - it just means that selecting this command will use 1 button
3. if you right click on the library node/ Filters/ Manage Filters you will see a list of filters and filter conditions. "view" is a column header for a new attrribute that allows the user to select which view (Album and Tracks, Artwork, Track Details or Default) that will be displayed when the filter is active
butty
Hi, thanks for the reply.
On my MB (2.0.4467), there is no Taskbar Player section in Preferences/ Player/. Is something wrong?
i should have said
Preferences/ Layout/ player section/ Taskbar Player
