Author Topic: Translator Q&A  (Read 529866 times)
silasje1
And back to five ;-)
Button should mention 'Aan bibliotheek toevoegen'
@silasje1:
Er gaat toch nog een lange waslijst aan verbeteringen aankomen, komt waarschijnlijk dinsdag je kant op...
OKE!!!! ben benieuwd :D
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
silasje1
silasje1
jistme
@Steven
Maybe also a bit wider window here to avoid this 'ugly' text return?
Ps,
Do you want us to keep filling this thread, or would you prefer a new subject for everything we encounter?
jistme
i will have a look at these items on the weekend
jistme
OK
One more (language independant)
I think it is not supposed to be possible to check both these options together?
jistme
#LBck.msg.Ttfntboadd#  The target folder needs to be on a different drive to {0}
#LBck.msg.Sttdaffff#  Select the target drive and folder for files from {0}
Last Edit: February 23, 2012, 01:24:51 PM by jistme
Maybe its worth to put your questions to already exiting for this purpose 'Translators Q&A' topic?
jistme
Can somebody please describe what the content/meaning of {0} is in below two lines?
jistme
Not the most important issue of the year, but more some wordplay with logics, I still think it should be mentioned:
Trying, but not succeeding in translating the item below in a correct and way completely making sense, I think the statement is initially wrong.
Shouldn't 'maximum' say 'minimum'? And after the input box something like '(by adding a maximum of ... zeros)'
Since you can't limit e.g. to 2 numbers, because after '99', it will become 3 numbers?
If it is intended to mean the number of zeros it will add it's also incorrect, since if you enter '2' in the box, it would add maximum 1 zero?
I think input before, and after the box should also be revised for English?
As I can see it from my translation {0} should be drive letter (eg 'E:' or 'F:'). Steven might want to correct me.
Also from my translation: {0} should be library name (I translated this string in manner '...and folder for files from library {0}').
jistme
Thanks boroda74
I will use your input, until Steven might have additional comments.
