Author Topic: Dutch  (Read 157442 times)
jistme
2.1.0.6 alweer:
download 'MusicBee NL taalbestand'
(Meteen ook maar Steven's nieuwste toevoegingen van vandaag vertaald en toegevoegd)
jistme
Album and Tracks layout:
albumafbeeldin... should read albumafbeelding
I know, the paint is still very wet, but there's no entry for 'Default Narrow and Wide' yet.
it wont be translated - the selection list is based off theatermode skin files in the folder
jistme
Just having some doubts about this one:
#PLE.ctl.E527F5A#   fit artwork to the size of the panel
It's not like that if you untick this, the artwork won't fit the panel.
Maybe "minimize margins (or 'space') between artwork" would be slightly more descriptive?
jistme
Vertaling up-to-date gemaakt:
(v2.1.0.8 )
@Silas, kun je hem op code.google.com zetten?
silasje1
Dankje jistme! Ben nogal druk met mijn opleiding dus ben niet erg actief helaas.
Google Code:
https://code.google.com/p/nl-for-musicbee/downloads/detail?name=Nederlands%202.1.0.8.lng
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
jistme
No translation entry for this yet.
Fmy, is this help indeed retrieved online? (so internet connection needed?)
jistme
While this one:
#NPL.ctl.8EB6C56F#   show track properties (bitrate, sample rate, channels, duration)
has a correct entry in the translated file, in the Now Playing Layout Configuration panel it still shows up untranslated.
(Also in some other languages that I checked)
jistme
Yep, the nitpicking gates are open wide now....
floating window transparency:   ------------------ opaque
should probably say:
floating window transparency:     transparent  ------------------  opaque
jistme
When I'm on a roll...
'now playing list' should probably say 'show now playing list'
jistme
The two small pull down menu triangles disappear here.
jistme
@Steven:
It might be important for you to know before making adjustments, I'm working on a new language file with a new adjusted width string. (2.1.0.9)
download Dutch language file'
silasje1
@Steven:
New version added:
https://code.google.com/p/nl-for-musicbee/downloads/detail?name=Nederlands%202.1.0.9.lng
Dutch Translation
WMP 12 Skin
jistme
Just to be clear, this is merely an 'internal' interim version, e.g. no support for the new compact player yet.
