Author Topic: Android remote  (Read 102991 times)
silasje1
All reading...
here are the downloads:
http://www.mediafire.com/?cviceff9iia73iz (the DLL for the pc client side)
The APK's
http://www.mediafire.com/?iu7b1ip69gc1zu2
or when that doesnt work:
http://www.mediafire.com/?kpp9kpquavle3f7
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
MasterP
App force closes on my HTC QVGA Android 2.3.7 (CM7) device.
But thanks for your work so far.
silasje1
try second link (this is noy my work)
Dutch Translation
WMP 12 Skin
MasterP
silasje1
kelsos
both versions didnt work
This is weird unfortunately I am not sure what would be the possible cause could you tell me the exact device? and any more info if possible, so I can try the next version in a similar setup (or emulated environment)?
Still since there was a lack of updates, the development still continues. I will start a new topic to make things easier as soon as a new test version will be available.
On the new version the server (plugin) will be able to do, along with allowing anyone to connect, IP filtering either by allowing only clients specified in a list of allowed addresses or clients in a range of from x.x.x.a to x.x.x.b.
On the application side there is a major re-design, (help from a friend) and at the moment I am working on the ability to display the track duration/progress bar information.
Unfortunately it takes a little bit longer than expected due to major rework of the code base.
Here is a screenshot of the application at the moment. The layout is almost final only needs a little bit of tweaking.
Last Edit: June 13, 2012, 01:07:38 AM by kelsos
Alexis
Wow......I can hardly wait.   Thank you so much for your dedication.
silasje1
Great work! if you need me to test anything just PM me ;)
Dutch Translation
WMP 12 Skin
Alexis
 I am not  familiar with how  the android market works, but I am willing to help with the setup fee if needs be (I think you indicated you were in college, so just trying to help if necessary)   Just PM me whenever.
I am really pleased that you will be doing a new thread for clarity.
silasje1
You need to pay to get an app in the google play store
Dutch Translation
WMP 12 Skin
Alexis
Ok thanks, i am willing to help.
scottjay
Fantastic! remote-no-notifications.apk is working on gingerbread! Can't wait to see more development. (The other version caused a force close.)
Edit: Unfortunately now it causes force closes for some reason. I don't know that anything has changed since
Last Edit: June 16, 2012, 12:09:43 AM by scottjay
Maleko12
Yeah, I'm having the same issue on my phone as well. Neither version works anymore :(
scottjay
I found the problem: my computer's ip address was changed on the network, but the app was reference the old ip address, which caused it to instantly crash until i cleared data and changed. notifications version still crashed instantly freshly installed
kelsos
Ok thanks for the information. I ll try to emulate it to find out the reason behind. The notifications version has issues with 2.3.x (and probably 2.2) devices. The device I use for development and debug runs CM9 (4.0.4) and in ICS the notification code works without Force Closing. I should have tested the code against a 2.2/2.3.x emulator image before getting the apk uploaded.
Last Edit: June 18, 2012, 12:10:37 AM by kelsos
