Author Topic: Few issues with mb3  (Read 7115 times)
user73
 hi.
  I know mb3 is still in beta phase but i like to point out some issues.
Its missing random skin option .
Playing track  is not highlighted in main panel like in mb2..though playing track is highlighted  in now playing panel.
MB3 at startup don't respond for almost 40-50 secs every single time.i installed MB3 in same directory.
its been solved by tompeto who posted his problem here
http://getmusicbee.com/forum/index.php?topic=17328.0
but im still searching for solution.
how can i remove track details at left bottam pan.i just want artist pictures.is this possible?
another question is why links are not shown in track information in left bottom pan while they are shown in right bottom pan?
thx in advance.
Last Edit: January 26, 2016, 04:12:51 PM by user73
can you send me:
MusicBeeLibrarySettings.ini  from the root MusicBee music folder
MusicBeeSettings.ini
StartupSettings.ini
MusicBee3Settings.ini
they are in the AppData folder where MB is installed if using portable mode
the only obvious thing i can see is you are using a different library - is it still slow when you use:
M:\Till2015\
if it makes no difference, i will need to give you a debug version, so could you confirm you will be happy to run a debug version. Could you also clarify some more about the 40-50 seconds. Is that the time before any window appears?
edit:
actually i am having a problem with your DSP settings.
dsp_enh.dll
can you try disabling that. From what i can see you dont have any enabled in v2.5
Last Edit: January 26, 2016, 06:51:51 PM by Steven
user73
Yes steven..you are right..after i disable plugin,Mb3 works fine..but it is best plugin i could find.Plz make it work with mb3 too.and surely im using it with mb2.
it is enabled in mb2 also ,i don't know why it is not showing in ini file.
btw the is dsp plugin i am using
http://winampplugins.co.uk/enhancer/
and regarding that not responding..mb3 not respond for few minutes..but i can see mb3 window..all the playlist and panels but just nothing is clickable but that is find if i disable that dsp plugin.
its does appear to be working with v2.5 so i will see if it can be addressed for v3
edit:
its fixed for the next v3 update
Last Edit: January 26, 2016, 07:43:02 PM by Steven
user73
thats great :)
can't wait for next update..
and can these also be fixed?
"how can i remove track details at left bottam pan.i just want artist pictures.is this possible?
another question is why links are not shown in track information in left bottom pan while they are shown in right bottom pan?"
user73
Hello..
im glad after new update MusicBee_Setup_3_0_5874 im able to use DSP plugin enhancer..but somehow mb3 still having issues.Playing track  is not highlighted in main panel like in mb2..though playing track is highlighted  in now playing panel...
I tried every possible method i could use..fresh install of MB2 in new directory..then updating to mb3..also deleting files in userdata\roaming..but its not working at my end..SO i need to ask is this only me or this issue has yet to be resolved in next update?..
since MB2 to has no such issue so im still using MB2..
Are you sure you have it configured?
Preferences > Now Playing > Playback > Highlight playing track in the main panel
user73
thx phred for replying..
yes im 100% positive..thats first thing i checked ..
but i need to ask is it mb3 running fine at your end regarding this issue?
Have you tried changing the color?
Absolutely fine.
That's strange. If you tick "color text" for main panel highlight setting, it doesn't work just like previous versions. Does it work for you?
For me it only works with "select track" setting.
user73
""That's strange. If you tick "color text" for main panel highlight setting, it doesn't work just like previous versions. Does it work for you?
For me it only works with "select track" setting.""
EXACTLY im also having this problem NOW..but earlier it was not even working if i don't choose color..So restarted PC again to confirm that it works and it is working fine with highlighted track selection and im fine with that.
but could anyone care to answer questions i asked earlier.
1.how can i remove track details at left bottam pan.i just want artist pictures.is this possible?
2.another question is why links are not shown in track information in left bottom pan while they are shown in right bottom pan?
I notice you are using an older version of my Tron Punk skin.
Just to be sure it might be good to download the most recent version for MB v3:
http://getmusicbee.com/forum/index.php?topic=7871.msg45607#msg45607
