Thank you, Steven.
Here's the MusicBeeLibrarySettings file:
http://www.mediafire.com/view/fgrv62uup8dd5gq/MusicBeeLibrarySettings.iniFull Path musicbee3 is located: E:\___System folder\Programas_sem_install\MusicBee\
Full path of my musicbee music library: E:\___System folder\Programas_sem_install\MusicBee\Music
I run the portable installation.
I think the only thing that's missing now is: (ALL SOLVED BY EDITING SETTINGS FILE)
- the command buttons I had configured; - SOLVED (by copying code from the corrupted file to the settings file)
- the highlight rules I had configured; - SOLVED (by copying code from the corrupted file to the settings file)
- the hotkeys I had configured; - SOLVED (by copying code from the corrupted file to the settings file)
- the Devices; - SOLVED (by copying code from the corrupted file to the settings file)
- the file converter configuration. - SOLVED (by copying code from the corrupted file to the settings file)
Here's the corrupted file:
http://www.mediafire.com/view/ad39dq9ek6e5iod/MusicBee3Settings_corrupted_20160122015522.iniUpdate: All being solved (for now), I leave this question:
Is it possible to have the bottom panel with the lyrics, artist picture and album cover like before?
