After having bothered everyone a lot, things are now working fine for me : I love my new customised Musicbee.
May I make a suggestion for the next update ?
I've configured my classical music collection this way :
Left : Selection of the artist with the thumbnail browser
Then : Vertical Panel Browser to browse by country, musical work (Symphony No.**, etc.)
Center panel : the different albums corresponding to the different performances of the same work, by different conductors.
I start by selecting either the country or the artist (see below for the selection of the artist : you can see the list of albums-works correspond to the artist). Then I select the work, and then the version I want to listen.
The problem is that there is no link between the Column Browser and the Thumbnail Browser : when I click on the work-album I want to select in the column browser, the artist previously selected is unselected and so all the other works-albums (from other artists) suddenly reappears in the album column (sea below). That's not very practical.
Other example : when you select a country, for example, it does not excluse artists that does not correspond to the selected country, so you can't use it to browse the artists.
I also understand one can open multiple tabs and customise their appearance (for example, album cover view in the main panel of the first tab / only tracks in the main panel of the second). It would be even better if one could also change the categories and width of the column browser from one tab to another (for example, year and country in the first / country and conductor in the second, etc.).
Example 1 : The general music configuration I would like to have in the first tab
Example 2 : A classical music configuration that could be in a second tab, allowing to swith between the two without having to reconfigure the column browser (which I had to do to take the screenshot).
I hope you understand what I mean...
Do you think such improvements could be easily introduced ? Or is it hard to do for you ?
All I would like to know is if I can hope for such an improvement or if I should just forget about it.
Thank you very much for your attention and all your good and dedicated work on MusicBee !
