Author Topic: Dark Skin  (Read 30482 times)
ild2
v4lve: i find the preferences window quite hard to read /cluttered with the black background in dark skin. maybe you could try to make the background of the preferences window gray, like in spotify b? i know this would hurt consistency in the skin but i think readability should go first here.
V4lve
Steven.  Any chance you can give me an specific element for this?
there are already separate elements for the input panels - just check out the spotify B skin:
InputPanel.Default
Controls...
V4lve
Here is a new version od "Dark" skin with lighter preferences panel
http://db.tt/rd4g52
ild2
thanks! looks much better
ps. maybe even brighter would work?
blast664
Could someone do a darker (& higher resolution) "album art is missing"-picture for this skin?  :)
its already included in the latest .exe - just get the links from the grey skin topic (the artwork applies to all skins)
V4lve
Couldnt find anything obvious in the grey thread.  How do I get it to work?
Rotem K.
use the latest .Exe ((http://www.mediafire.com/?gzmiojgwwyu) ...found at the end of the Grey thead) it should be there.
V4lve
Ta.  Is there any way I can change it for the Dark skin? Would like to use something like this
not at the moment but i will add an element to allow it to be specific to a skin
V4lve
Latest version of Dark Skin.  Now includes "no cover" artwork in keeping with the scheme.
http://dl.dropbox.com/u/133297/Dark.xml
You will need the lastest version of MusicBee
silasje1
looks very nice! could visualized drop down menu be included too? or is that a thing steven has to do?
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
andrea.ippo
My proposal, based on an old Dark.xml
It changes the color of the stars in the main panel to make them more visible.
http://shorttext.com/enpzeflsp0 (xml contents excluding the <images> tag)
Here is a screenshot:
Rotem K.
Made a Dependent skin with some fixes, small changes and a new splash.
- Some of the fixed colors where originally there in the skin but with time and after some new elements added things have changed.
- Some small stuff I changed to my liking.
http://www.mediafire.com/?vvy9k3w01wpc7ux
I've deleted the file from the online host, the fixes have be integrated to the original skin after beta v1.2.4083.
Last Edit: March 08, 2011, 01:07:35 PM by Rotem K.
