Author Topic: Internal Landscapes  (Read 14049 times)
Iasc
Internal Landscapes
Updated for MusicBee 3
This skin has been overhauled and is not the same as the original version
There are 2 skins here, one for people who have the player controls docked at the top and one for people who have it at the bottom.
Player Controls Docked At The Top
Player Controls Docked At The Bottom
INSTRUCTIONS
[2] Unzip it in the MusicBee Program Files/Skins
Icons designed by endeavour1934 and JMoss.
Last Edit: March 26, 2016, 06:06:44 AM by iasc
Wow, that's really cool!  Nice work.
Iasc
Iasc
bitmap sources download link added to first post.
Iasc
updated - fixed a minor problem with the star ratings.
Iasc
Updated for musicbee 3. This skin has been completely overhauled and is not the same as the original version. See first post for details.
Iasc
@ Steven.
When i updated this skin for Musicbee 3 it worked ok but now the image at the top of the player bar is distorted. Has something changed recently to cause this?
The top picture is how it should look.
Decreasing the font size distorts it even further.
Last Edit: May 22, 2016, 09:06:31 AM by iasc
the scaling doesnt work well until you restart MB.
while testing this, i noticed the following 2 elements dont load (you can check for skin errors in the error log)
ConsolidateButtonsIcon
PlaylistIcon
Iasc
I will fix the icons. Thanks.
Restarting musicbee doesn't seem to make any difference. I don't think i understand anyway, a restart was never necessary before, this skin is 3 years old and never had this problem before.
in older MB versions, it required a restart for the font to take effect.
Iasc
Maybe i'm still not understanding this. I'm not actually changing the font ( I can see how i gave that impression from my original post ). The image is distorted all the time.
Last Edit: May 23, 2016, 12:58:32 PM by iasc
in that case send me your settings file
Nothing is unusual with your settings. As a guess you are now using 125% DPI scaling for your computer. When i try that, it does what you show in the screenshot. MB is correctly scaling your background to 125% but because fonts dont scale proportionally, the text bar is much higher as a proportion of the total height
Iasc
Its set at 100%. When viewed in the skin creator it looks correct, in musicbee it distorted. I did a clean musicbee 3 install on my other laptop and it's the same problem.
This skin is also being strected - http://getmusicbee.com/forum/index.php?topic=10389.0
Last Edit: May 24, 2016, 12:35:36 PM by iasc
