Author Topic: Dark Matter  (Read 23897 times)
Iasc
Dark Matter
Updated for MusicBee 3
INSTRUCTIONS
[1] Download the file:  http://www.mediafire.com/download/fb191mrx2t00pyk/Dark_Matter.zip
[2] Unzip it in the MusicBee Program Files/Skins
Icons designed by endeavour1934.
Last Edit: February 16, 2021, 12:38:54 AM by Iasc
lnminente
WOW Iasc! You're getting better with this each day. Really nice work (Y)
Two small things in case you missed them: The hover pause button seems smaller than the normal pause button, and the love track button hover appears descentered to the bottom right.
The shift buttom for banning tracks works right, which is one of the most common bugs in bitmaps skins.
Thanks for you sharing (Y)
beeing good
Thanks, a very creative skin. I like it!
Iasc
thanks for the kind words.
@ Inminente - i hadn't noticed the problem with the last.fm love and have fixed it and updated the link. thanks
the pause and play buttons and highlight buttons are the same size. they are the same image with the colour inverted for the highlight. musicbee seems to be cutting them off for some reason.  if there is no fix for it i may have to make them smaller.
Last Edit: August 01, 2013, 12:01:17 PM by iasc
jistme
The fault is probably not in your skin.
I noticed recently that the play controls in my 'Ebony & Ivory' skin nowadays get corrupted too.
(they were fine, and I haven't changed anything)
i know what that probably will be but it might be a while before i can look at it
Iasc
ok. i will leave the skin as is until then. thanks
SimonBRT
noticed something similar on my modern skin also.  never got around to bringing it up.  glad that steven is aware.
that should be fixed for the next v2.2 update
jistme
In my 'Ebony & Ivory' it's now hunky-dory again.
SimonBRT
fixed for me in 'Modern' as well - thanks.
Iasc
Bitmap sources download link added to first post
Iasc
Updated for MusicBee 3.0. See first post for download link.
Cliff
I am using the Dark Matter skin and find it almost impossible to see the scroll cursor in the main window. This is even after adjusting the brightness on my laptop screen. Is there any way of changing the cursor color or shading? The cursor is supposed to be visible directly below the triangle in the image below.
Any help is appreciated.
I have moved this to the skin's thread so that the author will see it and perhaps offer some advice.
