Author Topic: Control musicbee with an iOS device  (Read 11716 times)
sbga420
Is there any way to control Musicbee using an iOS device? I tried using the DACP plugin and using iTunes Remote, Musicbee asks me to input the pairing code and then I get an error on the iPad "iTunes Remote can't connect to your iTunes library. Check your network settings and try again".
I was using Musicbee Remote app for android on my phone but I was gifted an iPad and I'd like to use it for this somehow. Unfortunately I can't jailbreak the ipad
Sorry, you're probably out of luck.  Maybe it's possible to write an iPad version of the remote, I can't speak to that.  But no one has yet.
vincent kars
if you can write code with a scripting language:
http://getmusicbee.com/forum/index.php?topic=11492.0
also this plugin lets you control MB from a web browser - its quite old and not sure if it still works:
http://getmusicbee.com/forum/index.php?topic=8366.0
sbga420
I think I'm going to try the DLNA server plugin http://getmusicbee.com/forum/index.php?topic=14277.0 because my receiver supports this and has a good app for iOS.
Adson
At the moment I use MB on my iPad via the Microsoft remote desktop app.
That works but it is not very convenient. I wonder if someone has found a better solution for controlling MB on iOS-devices.
Dan
It is now possible with MusicBee Remote application for iOS devices  ;)
Download on the App Store
MusicBee Remote plugin is required - https://getmusicbee.com/addons/plugins/199/musicbee-remote-for-ios/
Topic to discuss iOS application - https://getmusicbee.com/forum/index.php?topic=29413
Last Edit: August 24, 2019, 08:22:10 AM by dandepeched
