Hi everyone!
I will have a party @home for new years eve and I want my guests to add songs to the play list with their smartphones, download to their phones the songs that they like and see what is coming next... I've not been able to find any plugin like that so.. I've arranged one.
It's 100% alpha but it's skinable and modable.
To install just as usual copy the assembly and the wwwskin folder to plugins folder, configurationwise you can only change port, but if you take a look to the html you will realize that you can change pretty much.
To-do:
* bug fix
* add an admin mode so someone can delete / skip boring songs , change volume... meanwhile i will do it with the android remote!
I'm open to suggestions and i wish someone finds it usefull, but, (disclaimer) I offer the standard "no warranty", you are installing a binary on your system so it can delete things, mess up your pc / belongings / kill your dog.. etc
USE IT UNDER YOUR SOLE RESPONSABILITY
ChangeLogVersion 0.3.3b
- Wrong dll on 0.3.3 (stupid me... thanks V4lve)
Version 0.3.3
- Fixes on download & lyrics on playlist
- Fixes on search interface
Version 0.3.2
- New interface on now playing. I need sombody with an iPhone to test it, and someone with a small screen phone
Version 0.3.1
- Change ajax request to post to try to avoid some complains about media controls not working
- Added a refresh to panels after changing rating update to force musicbee interface to show new rating
Version 0.3.0
- Added media controls (Play, pause, stop, next, previous, there are Fast Forward and Fast Backward on the web server but not implemented on the skin, if someone wants to use them the commands are called C_FF and C_FB
- Added rating controls
Version 0.2.2
- Added dutch locale (thanks to Silasje1)
Version 0.2.1
- Added english locale
- Fully localized
Version 0.2.0
- Localizable! (now you can make your own localitzations of the texts, help needed!)
- Touch compatible using jquery mobile
- Lots of bugfixes
- (new bugs added for sure!)
Version 0.1.1
- Massive theme update, using jquery mobile, now it's visually better
DOWNLOAD
