- when you drag from the main panel in the left direction and the left sidebar is hidden then it will pop up automatically. I might change it to only do that if the left sidebar is configured as auto-open (as opposed to "hide") in case people dont like this new behavior
- Noticed this works only on Track Details view and Album & Tracks view. Is it intended?
- Popped out sidebar needs to push the whole panels to the right (1) when playlist manager is enabled, (2) when playing tracks list is placed on left main panel and (3) when only main panel is opened (as it would cover some fields).
- i have made a start on tab pinning - just right click on a tab/ Pin. I really havent tested it and off the top of my head still needs to move the tab to the left side when first pinned and inbox/podcast counters
Looks good. Some suggestions:
- As I suggested, consider displaying first letter too for nodes with the same icon like filters and playlists as tooltip is not enough.
- Noticed lock tab command still remains but it doesn't seem to do anything.
- I don't think it's a good idea to disable left sidebar for pinned tabs as that will seriously limit its functionality. Just allow it to show and if the user selects a different node, just open the node in a new tab and move focus to there. That's how web browses do for pinned tabs.
- Pinned tabs are not locked to its selected node (1) when search results node opens and (2) field links on track info panel are clicked. Open those too in a new tab.
