Hi
Is there a hack or setting (which I haven't found) in which I can enable in order to view the volume level as a number (preferably a percentage)?
The reason I ask is because at 76% on the dot the ASUS Xonar essence ST or STX is at maximum output, and thereafter it applies dynamic limiting, which can ruin big build ups in the music. And with the slider, although its well designed, I have no option to view at exactly what volume level the player is.
I don't think this is a major feature, and I don't think it should be enabled by default, but possibly just as a display option. I am not the only one in this situation over at Head-fi.org
P.S thanks for all the effort on this great player, I have converted over 20 people to use this
