Author Topic: XBox Music Style  (Read 72403 times)
endeavour1934
I've just made this simple config based on the new XBox Music "Now Playing" interface.
They use the standard Segoe UI fonts from Windows 8/8.1/10. Previous versions of Windows may be missing the Segoe UI Light font.
Lyrics hidden by default. A small icon will appear on the player controls if there are lyrics available.
XBox Music Style 2.0
Last Edit: November 30, 2021, 11:02:08 AM by endeavour1934
lnminente
endeavour1934
It works better with high res displays, yes. But it sould look good even at 1600x900.
yes i agree it looks great and i have a 1600x900 screen
endeavour1934
Updated version with smaller elements for smaller displays (Original version was designed for 2560x1600)
See first post :D
Last Edit: October 11, 2012, 06:13:04 PM by endeavour1934
silasje1
  • MB Version: 3.6.8878 P
I like!! Very minimalist  :)
dgbx
Thank you for the work you did on these excellent Theatre Modes.  Great stuff!
mikebo
While i don't use theaterMode, i have to say i like this style a lot. Thanks for sharing.
ShawnS
This is wonderful! I have always loved the Xbox Music/Zune colors and style. Thank you! I have been tweaking it some on my own and was wondering if you know or found out how to alter the pink/purple color tiles image. I wanted to play with it and try a few different images of my own. I'm still very very new to how Music Bee themes and skin stuff are built.
kingB
love it
just that the lyrics button doesnt seem to work 4 me
i keep on clicking on that book icon, but it dosnt work
maximinium
This is really beautiful!  ;D
However, I'm not able to get the lyrics to show. I checked if lyrics were available and it shows the booklet, but like KingB they don't show.
Solution:
If you change the XML file: (open with notepad), or rightmouseclick -> edit.
Then find:
 <!-- Lyrics --> subsection
right under it, you'll see that it says:
<autoHide name="#RightSidebarLyrics"
change it to:
<element name="#RightSidebarLyrics"
Restart Musicbee and it should work.
Hope it helped :)
Fantastic theaterview endeavour1934!
