Author Topic: LyricsReloaded  (Read 242667 times)
PancakePenguin
Great to see that people are still liking my plugin.
Thanks to emmaoninternet for the good providers and helping others here.
I kind of lost interest in the project as I moved entirely to Linux and I am thus unable to use MusicBee.
But for that reason I made it both open source on GitHub (including open feature requests) and as extensible as possible right from the beginning.
However if someone wants to take the project over, feel free to contact me (contact address is on my github profile).
If someone wants to sponsor me to keep developing the plugin, contact me in the same way.
Otherwise the development of the plugin from my side officially ends now.
Its pretty great how it is now. The next step I can see is synced lyrics. Thanks for putting work into this!
Bigmelwalter
For some reason this plugin doesn't work in MB3 Demo. Could there be an error on my part?
Could you be a little more specific?  How do you know it's not working?  I'm using it with no problems.
Bigmelwalter
I don't see the other sources for lyrics under the tags section. The only one's there are the default ones. Do I need to reinstall it?
I would suggest closing MB, and unzipping the DLL into the Plugins folder.  Even if the version you're unzipiping is the same as what's already there.  Then relaunch MB and see what happens.  As you are probably aware, the developer of this plugin has stopped development and if this doesn't work, you'll have to put out a call for help to see if anyone else has some ideas.
Bigmelwalter
I will try that. I am aware that the dev has ceased development.
Bigmelwalter
This comes up when I try to enable it
Last Edit: December 10, 2015, 01:57:37 PM by Bigmelwalter
Are you running MB 2.5 or 3.x?  Whichever one you're running, try it in the other.
Bigmelwalter
I'm using 3, should I delete 2?
No. Just don't have them open at the same time if you're tagging tracks, etc.
Bigmelwalter
I don't and I still cant get Lyrics reloaded to run
Sorry to say that I'm out of ideas at this point.  Maybe someone else will chime in with some suggestions.  It should work as it is working for me.
Alumni
Could it be that antivirus software or Windows security is blocking the plugin's .dll file?
h0m3r
I had the same problem.
Try Right-click on the mb_Lyrics Reloaded.dll
Click at the bottom on permit.
Hope that help.
sry for Germen Screenshot :)
Bigmelwalter
Hope that help.
So freaking happy!!!!!!!!!!!!!!!! Big Thanks h0m3r!
