Author Topic: Multivalue fields in now playing panel  (Read 3042 times)
Jorgen
Show all the individual genres under "track details" in the now playing panel.
Now only the first genre can be displayed.
Replace the ";" with "," between tags for other multivalue fields displayed in this view, like mood, occasion and grouping.
thats already supported - if you click the drop-down on the Track Information header, choose Configure Panel Layout and tick 'split multi-value tags into rows' (by the fields prompt)
However i see its not behaving correctly for genre and only shows the display genre rather than the multiple values as the other tags do, so this fixes that:
http://www.mediafire.com/?klycmiyndgd
Jorgen
Thanks for the quick response. Now you can display all the genres.
However it takes a lot of vertical space this way. Look at these 2 images. The first one is without "split multi-value tags into rows" selected, it looks good but only 1 genre.
The second screen shot is with the split into rows option selected, the keywords are cut of and it's not that easy to read the tags.
ok, i see what you mean. I'll change it so the multiple genres display later
Last Edit: April 01, 2010, 08:12:06 AM by Steven
