Author Topic: Tweak column resizing  (Read 2798 times)
mikebo
imho when using 'Keep colums sized to Panel' some columns should maintain their width (track, time, rating, bitrate etc.). I'd also make the artwork in 'Album and Track' view maintain it's size as it does in 'Artwork' view.
Also colums like track, play count etc. would look better right-aligned.
I agree that the small numerical columns should generally be fixed width.
Regarding right- and left- alignment, remember that you can change that though preferences.  It's Layout (1), Configure Fields.
mikebo
Thanks, I didn't know about that. Still I'd make it the default setting.
