it seems the Player_EndAutoDj() function is just stopping the player rather than turning off the dj
this has fixes for the auto-dj
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
Thank you, I'll try it.
I'm very sorry and ask You for your patience with me.I promise, that if you answer all of my questions, I end with this point (and in the worst cases I come to terms with it).
i know about this but because other plugins already have adapted to this behavior i dont want to change it
1. My understanding is, that change of the Player_SetRepeat() function behavior is not possible for backward compatibility. Is that correct? If not, why?
2. If so, it also means that "using the API will never possible to set Repeat mode to One"?
3. If so, why we can not use any other (new) function, which would not affect the work of other plugins?
4. Or any other option (which I do not know) already exists?
Again, I apologize for my impertinence. After all, I'm just trying to help you do MusicBee perfect.
Pako
