is it possible to type a letter and the list jumps to that letter?
Maybe a double list (two columns) would be easy to implement?
Yes, but only for those visible.
+1 it's definitely worth implementing as shown on the mockup in reply no. 8.
Quote from: VX on March 24, 2013, 05:32:59 PM+1 it's definitely worth implementing as shown on the mockup in reply no. 8.... or simply add support for using the scroll wheel. And set scrolling speed to 2-3 entries per scroll-wheel notch. That works extremely well for long lists (try that with Listary).
