Author Topic: Mathematical operators for virtual tags  (Read 18013 times)
  • MB Version: 3.6.9318P
Addition of arithmetic operators (as per MP3tag) to the virtual tag functions for any 'number' configured fields:
$Add(<field1>,<field2>) adds fields 1 & 2
$Sub(<field1>,<field2>) subtracts field2 from field1
would be greatly appreciated ( by me  ;D  )
I'm curious what you would use these for.
Gary Young
@Zak: As I stumbled upon both - this thread and the preceding - so here's the background:
http://getmusicbee.com/forum/index.php?topic=8979.0
Pingaware
I've had one or two situations come up with my virtual tags where being able to use very basic numerical operators (+, -, *, /) on tags defined as the number type in the Fields Layout panel would have been very useful. So far I've been able to work round these things, but I know I'm going to need to make a modification to one of my current virtual tags that I can't see a way round without being able to use something like <Virtual Tag 1>*2.
Any chance these can be introduced Steven? They would obviously only work for fields defined as the number type. I don't think anything other than +, -, * and / would be needed, possibly also with the ability to use brackets.
+1 from me and the other +1's from my wish for the same thing (http://getmusicbee.com/forum/index.php?topic=9008.0)
NB. Maybe a kind and helpful moderator could merge these 2 threads into 1?  Please.
Pingaware
I was pretty sure you'd have made a thread Bee-liever, as I saw in my search on the board that you'd found situations where you'd need to use them. However, totally failed to find that topic in my searching!
No worries Pingaware.
Took me a while to find it - and I posted that thread  :D
Pingaware
Apologies for the bump, but now seems the right time to bring it up again. (Inspired by redwing's wishlist bumps :P)
MeeMeeMee
I don't know about adding values of tags (of same track, I assume), I'd like to be able to display the duration of a group. Some examples:
  • Duration of CD1
  • Duration of Schubert's Piano Trio D929. All its track have the same Set Subtitle tag, and I use it in a sub-header virtual tag.
Maybe it's too specific or complicated for a function.
MusicBee 3.6.9154 / Windows 10 (64-bit) / Intel i5-3470 / 8GB RAM
Media on NAS (CIFS share)
Get the latest patch: https://getmusicbee.com/patches/
theta_wave
+1
Especially if a COUNTA function could be added (count fields that are not empty).  It could count # of tracks or albums for an artist.
