Author Topic: Tag inspector, delete multiple tags/frames  (Read 6562 times)
lnminente
I use to download new promotional songs from blogs, and i see myself frequently going to tag inspector, sorting the tags/frames by its value and pressing delete multiple times, for some songs it can be 30 times :o Would be very helpful a Shift+click for selecting multiple tags and deleting all of them pressing the - buttom only one time instead of 30.
In the example this song has only five tags/frames to be deleted,
Thanks in advance! (Y)
Last Edit: March 12, 2013, 09:23:25 PM by lnminente
Iasc
+1. would love to have a batch delete function for tag inspector
Acoustics
+1! please implement Shift+click selection for deletion.
Dizza17
+1
When the rich wage war, it’s the poor who suffer.
?? it has been implemented years ago (though not using tag inspector): tools> tagging tools> remove tags
True, but the functionality is not the exact same.
With the Tag Editor you see the contents of the tags that you may want to delete.
The Tagging Tools > Remove Tags function does not show the contents.
And it doesn't allow for deleting individual multi-value tags.
e.g.
only delete 'Baroque' from:
Genre: Electronic
Genre: Baroque
Genre: Pop
yes, hiccup, i was wrong. this topic is about another problem.
This is done for the next v3.6 update. Multi-select is only supported for the delete function
Last Edit: January 21, 2024, 07:40:45 AM by Steven
