The type-to-find function is in a way already present in MusicBee. It is just not very
visible (or perhaps even not very intentional).
If you select an item in one of the sorting boxes' lists or in the track list, you can jump
in that list (inside that particular box). For the track list, the keyboard search is done in
the column that currently is used for sorting.
So, for example, if you select a track in the track list and then type the sequence KNO on
your keyboard, you will jump to the first post in the list's sorting column that starts with
the letters K, N and O (not case-sensitive).
/Lakrits
Spikar'u'nte inglish? Föredrar du helt enkelt svenska?
Du hittar svenska språkfiler i
den här tråden.
Non loqueris lingua Anglorum? Grammaticus fastuosus Oxbrigiae es?
In
hoc filum documenta linguae Latinae nancisceris.
