Author Topic: (Embedded at bottom) Narrow waveform  (Read 17684 times)
lnminente
EDIT 130622===============
Finally found a trick for showing only the half top of the waveform automatically adjusting its height to the height of the panel. The problem is the plugin doesn't refreshes well, so you have to restart it clicking in another tab ("last.fm" for example) and in "Details" tab again.
Different polishes to maintain it usable using the minimum height for the panel
Download: http://www.mediafire.com/download/todeqakoq2dlcks/Narrow_Waveform_130622.xml
-No artworks, for people which have them in a sidebar
-Works well with dark and clear skins
-Possibility of also showing info about the artist or lyrics
(Old link removed having 75 downloads)
Note: The height of the bottom panel must be adjusted for seeing only the top half of the waveform as actually we can't set the height of the waveform as a calculation like "2 * Panel.Height - 15"
Last Edit: June 23, 2013, 09:52:25 AM by lnminente
ma_t14
lnminente
No idea whether it's this view or Theater Mode in general, but for some reason my embedded Theater Mode was suddenly showing the artwork for my selected track instead of the playing track.  Any ideas?
Edit: apologies, I didn't look closely enough and posted to the wrong thread.  Obviously artwork is not an issue here.  :)
Last Edit: January 10, 2013, 04:52:09 AM by scampbll
lnminente
( No idea for that, i will give attention to see if that happens to me too )
Jamesff
Um, the download link for this is broken. Are you going to update?
Still broken as of 2/9/2016. Any updates coming?
Last Edit: February 09, 2016, 05:37:32 AM by Jamesff
