Author Topic: All in One [UPDATED FOR XMAS] - For Embeded Theater Mode  (Read 30958 times)
Greb
I can't see anything that's different. This is the full line I changed in Greb's xml
<element type="Lyrics" xAnchor="Panel.Left" x="1060" y="155" widthDock="Panel.Right" width="-1082" heightDock="y:Panel.Bottom" height="-20" font="Segoe UI" style="Regular" size="9" fg="245,245,245" fg2="10,245,10" >
</element>
and it works fine.
BTW, the 255,255,255 was meant as generic, so you could pick a colour you wanted. I've used the green from the Artist name
</element>
and it works fine.
Yes, it does.  I copied yours over the original code and it worked just fine.  So that's a keeper.
Understood.  Personally, I like yellow (255,255,0) because I have a number of plain, darkish backgrounds that rotate through and yellow provides the best contrast.
@ Greb- Would you like me to PM the revised XML to you, or will you make the change yourself and post an update?
Too late for this update, but be sure this will be included in the next one.  :)
Happy xMas!
Last Edit: December 21, 2012, 11:46:36 AM by Greb
fredphoesh
INSTALL
Extract in the TheaterMode.Embeded folder.
Install the "Novecento Wide Book" fonts (included in the zip file)
Hi Greb,
The view you created looks very good.
I found a similarly named folder that works... I could not find a TheatreMode.Embeded folder... I hope that is ok.
C:\Program Files (x86)\MusicBee\Plugins\TheaterMode.List
tx
Mark
Last Edit: January 10, 2013, 12:14:26 PM by fredphoesh
The screencap for this is not loading.
Back up now, nevermind!
Last Edit: January 26, 2013, 12:40:08 AM by scampbll
Fredsky
hey Greb, ive modded your "All in One [S Size]" to b a screen saver and to fit my resolution, also done some modifications
its designed for 1920x1080 res (im in a 15.6' w/ 140% custom DPI settings, dunno if it will mess stuff for other ppl)
here's to any1 that finds use to it,
upload it, edit it, idk
maybe would be a nice idea to make a thread for it on the screen savers
(as i coudnt attch it here's the code)
<root>
<settings enableScaling="false" />
<settings backgroundImage="Blue sky.jpg" />
<settings rotationFolder="Book Lovers Dark Walls Embeded" />
<settings rotationPeriod="50000" />
<theaterMode>
  <settings bdr="128,128,128" />
</theaterMode>
<screenSaver>
  <settings idlePeriod="0" />
  <settings monitor="1" otherMonitors="blackout" />
</screenSaver>
<settings rotationFolder="Dark Backgrounds" />
<element type="ArtistPicture"  x="1430" y="685" width="450" height="350" aspectRatio="zoomKeep" fillColor="100,255,0,0" fade="0.0" interval="20" bdr="255,10,10,10"></element>
<element type="ArtistInfo" xAnchor="Panel.Left" x="05" y="430" width="355"  heightDock="y:Panel.Bottom" height="-75" font="Trebuchet MS"  style="Regular" size="11" fg="255,255,255" >
</element>
<element type="AlbumTracks" name="01" x="1390" y="195" width="500" heightDock="Panel.Botoom" height="-582" font="Trebuchet MS" style="Regular" size="11" bg="0,0,0,0" fg="240,240,240" mouseOverFg="190,190,190">
    <child width="15" />
    <child id="Speaker" width="27" />
    <child id="DiscAndTrackNo" />
    <child >.  </child>
    <child id="TrackArtistAndTitle" width="360" />
    <child id="Duration" />
</element>
<element type="Lyrics" xAnchor="Panel.Left" x="450" y="182" widthDock="Panel.Right" width="-1000" align="center" heightDock="y:Panel.Bottom" height="-40" font="Trebuchet MS" style="Regular" style2="Underline" size="15" fg="235,235,235"  fg2="255,255,215"  >
</element>
<element type="Block" x="458"  y="160" width="920" heightDock="Panel.Bottom" bg="0,0,0,0"></element>
<element name="#AlbumCover" type="AlbumCover" x="28" y="27" width="380" height="380" min="380" max="380" brightness="0" bdr="255,255,255,255" ></element>
<element type="Block" x="30"  y="0" width="352" height="-1052" heightDock="Panel.Bottom" bg="100,0,0,0"></element>
<element type="Block" x="0"  y="0" width="30" height="-670" heightDock="Panel.Bottom" bg="100,0,0,0"></element>
<element type="Block" x="0"  y="410" width="380" heightDock="Panel.Bottom" bg="100,0,0,0"></element>
<element type="Block" x="1400"  y="160" width="920" heightDock="Panel.Bottom" bg="0,0,0,0"></element>
<element type="Field" x="430" y="70" font="Rockwell" widthDock="Panel.Right" width="-490" style="Regular" size="18" fg="245,245,245" >
    <child fg="200,200,200" id="Artist"></child>
</element>
<element type="Field" x="430" y="33" font="Rockwell" widthDock="Panel.Right" width="-460" style="Bold" size="18" fg="245,245,245" >
    <child id="Title" reserveWidth="60"></child>
</element>
<element type="ProgressPosition" xAnchor="Panel.Right" x="-422"  y="23"  width="404" align="right" font="Rockwell" style="Regular" size="18" fg="205,205,205" ></element>
<element type="Field" xAnchor="Panel.Right" x="-115"  y="60" width="404" align="right" font="Rockwell" style="Regular" size="12" fg="180,180,180" >
    <child id="Rating" ></child>
</element>
<element type="Field" x="1750" y="63" font="Rockwell" widthDock="Panel.Right" width="460" style="Bold" size="11" fg="205,205,205" >
    <child id="Duration" reserveWidth="20"></child>
</element>
<element type="Block" x="436"  y="116" widthDock="Panel.Right" width="-500" height="1" bg="200,200,200,200"></element>
<element type="Field" x="1405" y="165" font="Rockwell" widthDock="Panel.Right" width="-505"  style="Bold" size="12" fg="245,245,245" >
    <child id="Album" ></child>
</element>
<element type="Field" xAnchor="Panel.Right" x="-1480"  y="120" width="404" align="left" font="Rockwell" style="Bold" size="12" fg="180,180,180" >
    <child id="Genre" ></child>
</element>
<element type="ProgressBar" x="437"  y="115" widthDock="Panel.Right" width="-462" height="3" fg="255,225,225,225" bg="13,0,0,0" ></element>
<element type="Time"  x="17" yAnchor="Panel.bottom" y="-80" width="140" font="Novecento Wide Book" align="center" style="Regular" size="32" fg="175,175,175"></element>
</root>
just save all of that into a .txt, rename it something like "All in One [S Size] 1920x1080 ScreenSaver.xml" and you're done
here's some pics of how it should look like
Last Edit: April 13, 2013, 09:11:25 PM by Fredsky
Greb
Upload the file and I'll add to the main post (creditting you, of course)
