Author Topic: (Embedded at bottom) Narrow One  (Read 27986 times)
outlander
outlander
Hi!
I liked very much yours embedded at bottom theatermode, and I modified it a little bit. Sadly I don't know much about modding, and came to dead end: how can I add next artist's names in album art queue? Check image if you don't understand my writings (something wrong with my keyboard.. ;) )
also, here's the xml-file, just-in-case, probably looks like shit :) It just isn't my thing...
http://www.mediafire.com/view/?twiv450qun44bf9
ps. thanks again for this theatermode, it's the best I've seen this far!
lnminente
The file you uploaded doesn't work, but doesn't matter i better will explain you how to play with it.
Remember the pattern i posted yesterday? It has 3 blocks: Cover, semitransparent dark box, and title of the track. The easiest way for adding Artist text as a fourth block, is copying the title element and modifying. So for the first cover you will have to add
<element type="Field" id="Tracks[1]"
xAnchor="#AlbumCover1.Left" x="0" yAnchor="#AlbumCover1.Bottom" y="-16"
widthDock="#AlbumCover1" width="-2" height="20"
font="Segoe UI" style="Bold" size="9" align="center"
fg="186,186,186"
><child fg="TrackAndArtistPanel(86)" id="Artist" ></child>
</element>
Modifying the bold text will change vertically its position. Maybe you will only need changing Bottom for Top from the mockup you posted. When you have it in the position you like. Add that fourth box to the other covers too incrementing the values for the different covers
Ps: Thanks for the kind words! The version with the next covers added only had 9 downloads yesterday, strangely not as welcomed as i thought :/
Last Edit: March 22, 2013, 10:23:10 PM by lnminente
