Author Topic: Logitech LCD  (Read 52591 times)
Ronin47
slimmeke
Version 2.0 RC1 is released today.
This release will be the 2.0 release if there aren't bugs found.
Changelog of 2.0 RC1:
- Added rating (most asked feature)
- Settings screen
- Added not always on top (you can change it in the plugin settings in MusicBee)
Have fun with it.
If you find any bugs please report them on:
https://bitbucket.org/jimmyD/musicbee-logitech-applet/issues?status=new&status=open
and I can fix this.
slimmeke
Version 2.0 RC2 is released today.
Changelog of 2.0 RC2 (02-07-2013)
- G19 users can now rate.
- Rating is added to the screen
and I can fix this.
MeekLogic
Just got 2.0 and I can't thank you enough. Love my keyboard and this plugin!!!
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." -Martin Golding
slimmeke
Version 2.1 RC1 is released today. This RC will be the final release if there is no issues found.
You can download it from:
https://bitbucket.org/jimmyD/musicbee-logitech-applet/downloads
The changelog of this version is:
- Added MusicBee volume changer
- Fixed some random crashes
If you find any issue please report it on:
mrad
I'd love to see photo of this in action so that I can drool and then head down to the store to buy one ;)
It would be special if owners add their device images on this thread so this becomes a little gallery of various models :)
Last Edit: October 07, 2013, 06:58:38 PM by mrad
slimmeke
mrad I have added screenshots to my project wiki's. You can find it at:
https://bitbucket.org/jimmyD/musicbee-logitech-applet/wiki/Home and
http://musicbee.wikia.com/wiki/Logitech_LCD
Last Edit: October 08, 2013, 07:43:43 AM by slimmeke
slimmeke
Version 2.2 of the Logitech LCD plugin is released.
Added some new feature (music control page) and bugfixes.
It's now possible to control MusicBee on a fullscreen app where the Logitech Media keys does not work.
You can download it at BitBucket:
If you find some issues please report it at:
Ronin47
Just thought i would help out with posting this,
Running latest beta had just right clicked and enqued a folder containing an mp3 album
any more info needed just shout.
MusicBee v2.3.5173.16173 (Win6.2), 18 Mar 2014 12:52:
System.InvalidOperationException: Object is currently in use elsewhere.
   at System.Drawing.Graphics.CheckErrorStatus(Int32 status)
   at System.Drawing.Graphics.DrawString(String s, Font font, Brush brush, RectangleF layoutRectangle, StringFormat format)
   at GammaJul.LgLcd.LcdGdiText.Draw(LcdGdiPage page, Graphics graphics)
   at GammaJul.LgLcd.LcdGdiPage.DrawCore()
   at GammaJul.LgLcd.LcdPage.Draw()
   at GammaJul.LgLcd.LcdDevice.DoUpdateAndDraw()
   at MusicBeePlugin.Logitech.TimerCallback(Object state)
   at System.Threading.TimerQueueTimer.CallCallbackInContext(Object state)
   at System.Threading.TimerQueueTimer.CallCallback()
   at System.Threading.TimerQueueTimer.Fire()
   at System.Threading.TimerQueue.FireNextTimers()
   at System.Threading.TimerQueue.AppDomainTimerCallback()
late
A very minor thing I noticed is that when going to Preferences -> Plugins ->Musicbee V2 -> Configure, pressing save seems to do nothing,
if I press save it seems to save the settings, but doesn't close the small menu itself. As you have to press either X at the top right or cancel to close it I can't be sure if the settings were saved. By looking back to the settings it would seem they are, but you can't really be too sure.
This is nothing big so this shouldn't be a primary focus.
ChristopherE
A really good plugin. Thanks for that.
Have you thought about adding scrolling lyrics?  I am using mini lyrics as well as your plugin but it would be much nicer to have it all in the one plugin.
Using the latest version on a Logitech G13 at the moment.
slimmeke
Mr. late I will add this 'closing settings window when saving' to the next release :).
ChristopherE I will look if it possible to add scrolling lyrics in the plugin.
Ronin47 sorry for this. Wich device do you using?
slimmeke
Version 2.3 beta 1 is released today.
This release will be the 2.3 release if there aren't bugs found.
You can download it at:
Changelog of 2.3 beta 1:
- Code rewritten (for better adjustability)
- G19 users can use own backgrouds
- It is now possible to enable and disable screens
- Better error handling
- G19 users can now enable Volume screen like G15
- Added lyrics page (Only for G15, G19 will be added in final version)
- More customization possibilities
Have fun with it.
and I can fix this.
slimmeke
Version 2.4 is released today.
Changelog of 2.4:
- Added lyrics screen
- Fixed some issues
Have fun with it.
and I can fix this.
