I really like the option to show the now playing track in a different color. It would find it really helpful to also have it show the track in bold font to make it easier to see.
Quote from: scampbll on November 17, 2012, 09:18:28 PMI really like the option to show the now playing track in a different color. It would find it really helpful to also have it show the track in bold font to make it easier to see.preferences - now playing- playback
personally i don't really see the need to have it in bold as well. but if you don't ask you don't get.
Would REALLY like to be able to keep selected files collected while resorting by column.
That was a bit of a typo. Was supposed to say keep selected files selected. In other words, reorder them, just keep them highlighted.
Quote from: scampbll on November 18, 2012, 01:49:45 PMThat was a bit of a typo. Was supposed to say keep selected files selected. In other words, reorder them, just keep them highlighted.Selected files can change around a bit. If you display the checkmark column (the first option under "Other fields"), you can left-click that column to "tick" files. Files remain ticked when reordered, and you can then right-click to "Select Ticked Files". A little convoluted, but it lets you keep tracks selected even after changing views and applying filters.
Sorry, I'm back again. The one thing that would make the check boxes perfect is a "check selected" option. Is there one that I'm not seeing?
