Author Topic: Color Coding Feature for Songs [Highlighting]  (Read 53364 times)
Gary Young
Just curious and looking for some inspiration - what rules are you guys using together with this feature? :)
Quite unspectacular but very important for me - I use it to grey out tracks which I only have as 20 second "previews", and not as full length tracks. I assigned the genre "Preview" to them and the rule is as simple: [Genre] [is any of] [Preview] with this result:
It works just perfect :)
Providing a rule-based formatting system is really a great thing und a unique feature among music-managers, I think.
I've just assigned different colours for different file types.
Useful to me because if it's an OGG file, I know it's a track I've ripped myself and therefore good quality.
Also makes it easier to identify ASX files which are referencing other files.
It would be nice to highlight tracks that are missing replay gain info, but Track Gain isn't an option on the rules list. :(
Last Edit: November 12, 2012, 09:22:36 PM by Zak
beeing good
Only just exploring this feature but it seems very powerful. I've set up 128kbps files to be shown in red (which I intend to replace with better quality versions) and two other colours to show tracks in two playlists I sync my Sansa Clip to.
lnminente
This thread is difficult to find for a new user, suggest adding highlighting rules to the title
Made it so.
I wonder why this feature is located under Tags(2) instead of Layout section of Preference?
Might be hard to find.
I think it's a little fuzzy as to where it goes.  I think it belongs right next to filters, personally.  They're different versions of the same idea.
lnminente
It think it depends how you use it, if have enabled the highlighting column you could understand it like a virtual tag.
But if have that column hidden and use it to colour the text then it can be understood like something in layout.
True, it technically can work as a highlighting "tag."  I'd still advocate for putting it right next to Filters, because the use the same system to set up and someone might decide that one or the other works better for their needs.
murve33
Not sure if this would be wanted by everyone, but I'd like it if the highlighted track's Star Ratings were the color of the specified highlight.
jamburglar
Is there any way to highlight songs whose title=30 characters? Another program truncated a bunch of my tags, so this would be pretty useful for me.
Create two virtual tags:
Virtual1=$Replace(<Title>,$Left(<Title>,30),)
Virtual2=$Replace(<Title>,$Left(<Title>,29),)
Create a highlighting rule:
match:all
Virtual1 has no value
Virtual2 has a value
It will do the job.
  • MB Version: 3.6.9255 P
You can also use:
Title matches RegEx: ^[^\r\n]{30,30}$
straight into the highlighting rules
