Author Topic: Theater Mode suggestions  (Read 27965 times)
Greb
Not working for me.
And besides, the windows size is a bit smaller than should be  ???
Not working for me.
the sizing? playing the next track?
If its playing the next track i have no problems with the latest .exe and your xml file so you would need to give me a description of what you are doing
the setting applies to the entire musicbee window - i might change it to account for that so the panel itself becomes the fixed size. Are you talking about 16px
Last Edit: November 30, 2012, 06:40:59 AM by Steven
Greb
For example, if I play any track, when reaching the end of the track this window pops up:
No way to keep playing until I get out from the theater mode.
Using the Main player view or using the same theater mode without the fixed size settings works OK [I tried].
is there anything in the error log?
It works fine for me so it looks like i will need to give you a debug version which i can do tomorrow
Greb
Here it is:
30/11/2012 6:48:40 - 6.1.7601.65536 - 2.1.4716.33636 - System.NullReferenceException: Object reference not set to an instance of an object.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at #=qZ8yeV6WTglxnMPU21BlRrjuUixvnt4Co7ywxMD6KyS9LGZX62hMq8kioYkVnhKwe.#=qTaUnGd3Ghkz5FdwtTtNnjw==(Delegate #=qyB2jfIABFKZkJFuLw_fuww==, Object[] #=qhdAJ77aUqiVxNtr1uZ382w==)
   at #=qtJxDcxmyM9hHvPvU5HO$zaPij2l2AxzWMMWhPjP6olk=.#=qoANbhH2atIr0d9hHu8UB07UjRHULyPxbAGltnKg31WU=(Boolean #=qUj1e8u$ggOqMMC846RfaCsYwz5jnw0M_J7kjceZizCc=)
   at #=qtJxDcxmyM9hHvPvU5HO$zaPij2l2AxzWMMWhPjP6olk=.#=qW$V1gNeJjkSvVR6qLlZVTFfv5N6iXBe008ieb72hUac=(Boolean #=qKz$3ker$Kbge$l_QqdlxETVTd5mSaRXz7c_VBVBptKk=)
   at #=qJWdiUuJ2w$pceHbBW5mRYuQXEz5fc40vLAmM0_nGPPg=.#=qnXxCKwJ_J0SiEEThbkiLt$qxNKDJ1zYuTb8Ey3evp3c=(Boolean #=quqV6m4asVjJkQOBqIIDouNyvIyInh_GP3rTK7f9HAoE=, Boolean #=qckB1$rY8op3LD7YCZmp8m$uoSsNSiaMYJKKbb8mRxs0=)
30/11/2012 7:56:07 - 6.1.7601.65536 - 2.1.4716.33636 - System.NullReferenceException: Object reference not set to an instance of an object.
Greb
By the way, much easier to handle if the size corresponds to panel, not to whole window!  :)
i have changed it so the fixedWidth and Height set the panel.
Also if you have "playback follows cursor" enabled in the Now Playing preferences then the bug is fixed. If you dont have that setting could you post a screenshot of your Now Playing preferences.
I will make a new version available tomorrow
Greb
No need to further search. It was that. I had this option checked. I unchecked it and no problem.
Greb
By the way, Steven, would be it possible to give the option to composed fields to be multiline?
i dont know what you mean by composed
Greb
Like, for example:
<element type="Field" xAnchor="Panel.Left" x="165" yAnchor="Panel.Top" y="390" width="520"   align="left" font="KG Shadow of the Day" style="Regular" size="14" fg="15,15,115"  >
  <child>the track lasts </child>
  <child id="Duration" ></child>
  <child> and it's the </child>
  <child id="TrackNo" ></child>
  <child>th one</child>
</element>
(Of course, that includes the 'normal' fields too}
this has the fix for the Now Playing setting and the tweaked behavior for the fixed panel sizing
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
Clownmite
Steven, thanks for implementing these suggestions!
oracio
Hi Steven,
I thought to add to this thread few other suggestions regarding the great Theater Mode you have created.
1. It would be great to be able to have the "aspectRatio" property when setting background images through the "settings" tag.
So if I put in my rotation folder, images with different aspect ratios they won't squeeze and stretch, just like with the "Gallery" element.
2. I have special tags that I have set to my songs, which I use to write long text, just like in the Comments tag. It could be great to have a property that tells a "Field" tag to be multiline / textbox which you can set its height and width, and the text will break by the size you have set, and if it is too long it will add a scroll bar - just like the "ArtistInfo" and "Lyrics" elements, but it will be optional to the "Field" tag.
3. There are some Theater Mode skins that have a list of songs that are coming next. It could be great if there will be a way to set it easily so this list of songs will be active and clickable so by clicking them MB will play the corresponding song.
Thanks again for a great product and features!
the 3 items have been done
1:
  <settings backgroundAspectRatio="keep" />
or any of the other ratios
also to set the fill colour
  <settings backgroundFillColor="0,0,0" />
2:
multiLine="true" and set the width and height
<element type="Field" id="Comment" xAnchor="AlbumCover.Right" x="30" yAnchor="AlbumCover.Top" y="-3" xwidthDock="X:Panel.Right" xwidth="-300" width="120" height="100" multiLine="true" font="Arial" style="Bold" size="12" fg="250,250,250" ></element>
3:
onClick="PlayNow" will use the element index
<element type="Field" id="Tracks[2]" xAnchor="Panel.Right" x="-260" yAnchor="Tracks[1].Top" y="60" width="250" font="Arial" style="Regular" size="9.75" fg="180,180,180" onClick="PlayNow">
  <child id="Artist" />
</element>
Last Edit: December 02, 2012, 08:54:09 PM by Steven
