Author Topic: Theater Mode suggestions  (Read 22483 times)
Greb
i have changed it so sizing attributes are now respected (note that in the zip file you sent, the png file has a different filename so is not loaded)
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
<element type="Icon" image="Images\Book Lovers - Frame 1600x900.png" x="1" y="1" widthDock="Panel" width="-2" heightDock="Panel" height="-2" ></element>
I cant easily solve loading 2 different artists at the same time and will leave that unaddressed
@Roadrunner, this version has the change that might solve the sizing issue for you
Well, thank u anyway for trying, and for the png stuff.
An issue I found while playing with Theater Mode is that the new "Icon" element's onClick event doesn't work with the OpenAutoHidePanel() function.
thats done for the next v2.1 update
