ive just done a few quick test runs but when i restart the playlist after it finishes it just plays the last played track and than stops again. am i missing something?
edit- bearing im mind that i am using the android remote to restart the playlist and not using the music bee program on my pc, so i cant double click on the auto playlist to restart it.
Yep, not being able to click the playlist might be a problem.
Depending on what commands you can map to your remote, you could try this to avoid getting get out of bed:
* Play the playlist in shuffle mode - this is to make MusicBee play all items in the list, even if you play the last track first
* To load new tracks into the playlist, select
View > Refresh* Map a button on your remote to the MusicBee command
Playback: Play now - this plays the track that is actually selected, not the track that was previously loaded
* Go back to sleep
